Feb 18, 2014 2:08 PM UTC
Integrating Vericut
Just tried to integrate vericut with Creo yesterday. When Vericut is launched from Creo, version 7.1.5 launches. I spoke with IT (new machine) and 7.1.5 has never been installed on the machine. When I run it independant of Creo, I run version 7.3.
Any thoughts on what's going on, or thoughts on whether running Vericut through Creo is any better than running it on its own?
Matt
Feb 18, 2014 3:49 PM UTC
Matt,
Vericut 7.1 is included with Creo 2 distribution. It was installed when Creo was installed. This is typicaly called embeded-mode
The main disadvantage of running in embeded mode is that it only runs CL files. You can't verify the actual machine code.
On the other hand, embeded mode does not require to have the machine controller and geometry defined.
In our office every time we are running the standalone mode most of the time. The only machine where we check the programs on embeded mode is an old 3-axis machine.
If you search the knowledge-base there are few articles that are describing how to set-up Creo to start in standallone mode. Here is one of them: https://www.ptc.com/appserver/cs/view/solution.jsp?n=129496
I hope this will help you,
Gabriel Zaha
Matt,
Gabriel Zaha
razmosis14-AlexandriteAuthor
Feb 18, 2014 6:10 PM UTC
Thanks Gabriel, it certainly is a big help! Even if you cannot use them together to verify code, the graphics are a lot better than Creo's default NC check. Is there any disadvantage in using it in that way, then opening Vericut to verify the code independantly?
Matt
Feb 18, 2014 8:47 PM UTC
Personally I don't see any disadvantage in running Vericut independently.Setting up a simulation take a little longer. We have a library of templates and this is helping us to save a lot of time.
Beside checking for collisions and part gouging we also verify other things like the amount of stock left for hard finishing operations. Bottom line: for us running Vericut independently is advantageous.
