Using Solve Block to Find Zeros and Asymptotes ?
- April 6, 2012
- 11 replies
- 4154 views
Hi all!
I have a problem getting the zero points and the asymptotes for my function through using Solve Block (see attachment).
For the zeros I am getting as a result from find() only one value (but the function has two zero points between 700 MHz and 2700 MHz), and this value is wrong (is not in the defined range of frequencies under "constraints").
For the values of the asymptotes no idea how to get them.
Any help please?
P.S. Is it possible to draw the asymptotes directly on the plot region?
P.S. Is there any possibility to zoom in the graph ?
