Test Topic for Images only
  • May 16, 2018
  • 3 replies
  • 45 views
Enter some text here.
And Then a pic.
    Dale_Rosema
    If it was for using the snipping tool and pasting, it doesn't work in the reply to cut and paste.
    I just pasted the image below from the Windows 7 snipping tool.
    EDIT: Nope. It pastes into the dialog box and looks fine but it fails with the error "Message cannot exceed 20,000 characters.".  If I then look at the HTML version, the image is a loooooong string of gibberish.
    Are you wanting us to test things? Or comment on the image upload process, which is terrible?
    Trying to enter the very same pic below via copy and paste
    Looks like I was successful. But not without problems:
    The first time I pressed "Post" I got the message
    And after pressing "Post" again all seemed OK.
    BTW I also tried to insert the screenshot above via paste from the clipboard but nothing happened when I pressed Ctrl-C. So I still had to save it and insert it the cumbersome way.
