Coversheet Extension - Get Task details from Change Notice
  • May 18, 2026
  • 26 views
I want to add a Coversheet to the representation that shows the different tasks completed by the users as part of a change over the WTDocument. Using the Tasks, Change and Change Task drag-and-drop, I don’t see my requirement being met. I was also unable to find good examples, if there is anyone who has implemented them or has good examples on the configuration, please drop your insights and suggestions.
Hari
Hi ​@HS_11022247,
I am not sure whether your use case can be fulfilled through an extension.
However, such use cases can typically be achieved using a Lifecycle Delegate.
