Dimensions disappear on a drawing
  • February 13, 2019
  • 3 replies
  • 14417 views
I have a part file and a drawing file. I have extensive dimensions on the drawing but need one with more basic dimensions so I do a save as and rename a copy. I delete the dimensions not needed on the copy, save and print it. The problem is that the original drawing no longer shows the dimensions that were deleted on the copy. Stranger more is that when opening the original drawing the preview shows the missing dimensions.
This has happened in both Creo 3 and 5 on 2 different computers one multiple file sets.
Best answer by StephenW
Article - CS17143
Effect of setting "create_drawing_dims_only yes" in Creo Parametric
Created: 04-Feb-2011   |   Modified: 01-Dec-2017
Applies To
  • Creo Parametric 1.0 to 4.0
  • Pro/ENGINEER and Creo Elements/Pro Wildfire to Wildfire 5.0
Description
  • Effect of setting "create_drawing_dims_only yes"
  • What are the limitations when setting config.pro option "create_drawing_dims_only" to "yes"
  • How to create the dimensions saved within the drawing
Resolution
Dale_Rosema
You need to "erase" the dimensions (hide them) and not delete them from the "Saved As" copy.
Deleting them will remove them from both the "Save As" version and the "Original" drawing.
dksix1-VisitorAuthor
I understand what you're saying but why does the dimensions that was deleted from the new drawing (created through save a copy with a different drawing name) still appear in the preview of the original drawing?
These are manual added dimensions on the drawing (drw) not dimensions driven from the model.
StephenW23-Emerald IIIAnswer
Article - CS17143
Applies To
Description
Resolution
Dale_Rosema
For non-windchill environments, if you have your extensions turned on in your files  (12345.drw.23 - where .23 is the 23 iteration of the drawing 12345.drw). You might be able to delete the latest iterations before when you deleted the dimensions from original drawing so that you do not have to recreate them.
So if you did this at 12:30 this afternoon, remove, quarantine, or delete the iterations before then to get back to where you were.
I tried that first. I deleted the newly created drawing which had the dimensions deleted as well as new versions of the original drawing. That took it back to the version that's dated from 2018 and I also emptied the programs memory. I also shut down and restarted CREO 3, tried it another set of files in CREO 5. Both my versions use the same config pro file as well as the other machine this occurred on.
I had this happen to me a few times before with no luck restoring them back.
Problem and Solution:
I believe this happened when I hit "Save a Copy" of the drawing into a new directory with a new name. This, for some stupid reason, resaved my open .prt files in my working directory as the next version (ie, from example.prt.1 to example.prt.2), and deleted the dimensions associated. Therefore, when I opened my drawing after closing and erasing, from the working directory, the dimensions were missing. I simply deleted the .prt file versions that were created at the same time stamp that I "Saved a Copy". Cleared and erased, and then reopened the drawing, and BAM dimensions were back!
