Disable regen while using "repeat" assembly command?
I have an assembly of medium size. I use the "repeat" command to assemble hardware. During the "repeat" operation, when I add each individual piece of hardware, it pops up a "regen" dialogue box which takes about 5-10 seconds to complete. Is there any way to suspend regeneration until I've completed the repeat command, then just regen once, instead of after each individual fastener? I don't see the need for multiple regenerations during a single "repeat" operation.
