FIXED LENGHT OF DATUM CURVE
hello everybody,
is it possible to set a relation in which fix lenght od datum curve?
thanks
hello everybody,
thanks
No. And the reason is that the flex of the cable is a deformation relaxation optimization problem** that depends on the flexibility of the cable and the end conditions, which is far above the capability of a parametric modeler.
What most people do is look at the installed length of the cable and use that value to drive the straight length so they part as-procured will be long enough to be installed. You also need to verify that the curvature of the cable isn't higher than allowed (or the radius smaller, depending on your viewpoint) and, if that's a push-pull cable, that the path doesn't create too much internal friction due to the routing. While the curvature can be checked, the friction is beyond the parametric modeler to determine.
**you would be looking for the case of minimum strain energy stored in the cable in both tension and torsion, which is where the end conditions can have a big influence.
Enter your E-mail address. We'll send you an e-mail with instructions to reset your password.
