How to change the default insertion point of parts or assemblies being assembled into a large modal
When initially bringing a part into an assembly using "main Window" mode, but prior to placing the part, can you change the default incoming position relative to the assembly, maybe there is a config setting that allows the new part to appear in the current window, zoomed in to the spot you want to add the new assembly item?
Why am I asking - On large assemblies, the new incoming part enters the assembly model very far from where I want to place it (way off screen). It takes a lot of mouse work to drag it over to where it needs to be placed. Why am I not using the "Separate Window" mode in assembly? Because the separate window mode is quirky and difficult to use, in my opinion - parts almost always end up upside down or end up being unassembleable forcing one to use the main-window assembly mode.
