Would it be possible to request an enhancement to ModelCheck?
Specifically, I would like ModelCheck to be able to verify the Bend Allowance settings. For example, I would like to check that for sheetmetal parts, the “Bend allowance driven by” option is correctly set to be driven by the material.
Even further, I would like to validate that the Sheetmetal Preferences are consistent with the smtdsnsetup.smd configuration file.
Thank you in advance if this request could be considered.
Adrien Blazy
You can submit your idea here.- "Creo Parametric Ideas":
https://community.ptc.com/t5/Creo-Parametric-Ideas/idb-p/creoparametric
https://community.ptc.com/t5/forums/postpage/board-id/creoparametric/search-before-post-mode/true
