Using wildfire 3.0
Hi.
How can i print to pdf file and use all size of de paper.
Even if i use a diferent printer , the result is the same.
See file.
thank you
My config.pro
! -- Config.pro -->- Printing & Plotting
delete_after_plotting yes
pen_table_file E:\Ptc\TCA_Configs_WF3\print_plot\canetas.pnt
plot_file_dir .\
plot_linestyle_scale 1.50
plot_names YES
plot_to_scale_full_window no
plotter ms_print_mgr
plotter_command WINDOWS_PRINT_MANAGER
pro_plot_config_dir $configs_tca\print_plot
raster_plot_dpi 400
rotate_postscript_print Yes
shaded_postscript_background NO
use_8_plotter_pens yes
use_software_linefonts NO
variable_plots_in_inches no
Please post this message in "Creo" community, here: http://communities.ptc.com/community/post!input.jspa?containerType=14&container=2023
Your print manager probably thinks there are keep out margins on your printer.
Typically, if you print to exact scales, you should get what you want.
I am assuming here that the drawing border goes right up to the edge of the paper size(?)
I do not use the print mamager and print to PDF using the Save-As Export functionality.
There are no scale options using this method. I can let the windows manager deal with Adobe instead.
one question that could be posed, however; does a scaled print through the print manager also scale the line weights?
