Printing to pdf file
  • April 29, 2014
  • 1822 views
Using wildfire 3.0
Hi.
How can i print to pdf file and use all size of de paper.
Even if i use a diferent printer , the result is the same.
See file.
thank you
My config.pro
! -- Config.pro -->- Printing & Plotting
delete_after_plotting yes
pen_table_file E:\Ptc\TCA_Configs_WF3\print_plot\canetas.pnt
plot_file_dir .\
plot_linestyle_scale 1.50
plot_names YES
plot_to_scale_full_window no
plotter ms_print_mgr
plotter_command WINDOWS_PRINT_MANAGER
pro_plot_config_dir $configs_tca\print_plot
raster_plot_dpi 400
rotate_postscript_print Yes
shaded_postscript_background NO
use_8_plotter_pens yes
use_software_linefonts NO
variable_plots_in_inches no
Good reccomendation Vladimir, I've moved this discussion into the community.
Your print manager probably thinks there are keep out margins on your printer.
Typically, if you print to exact scales, you should get what you want.
I am assuming here that the drawing border goes right up to the edge of the paper size(?)
I do not use the print mamager and print to PDF using the Save-As Export functionality.
There are no scale options using this method. I can let the windows manager deal with Adobe instead.
one question that could be posed, however; does a scaled print through the print manager also scale the line weights?
