Purge Issue
  • January 29, 2022
  • 2 replies
  • 1042 views
I am using Creo Parametric - Release 3.0 (connected) Release 3.0 and DatecodeM190
There is difficulty facing regarding the purge
Here are the errors that I faced
'x86e_win64_ptc_setvars' is not recognized as an internal or external command, operable program or batch file.
Could not find ****\ptc_setvars.bat The system cannot find the path specified.
    1. Read the following article: https://www.ptc.com/en/support/article/cs23606
    2. There was a similar question before - "PTCStatus not working": https://community.ptc.com/t5/System-Administration/PTCStatus-not-working/td-p/175955
    how do you launch purge ?
    Do you launch purge.bat located in bin subdirectory ?
