Round up values in drawing table - calculating issue
- August 24, 2020
- 2 replies
- 4659 views
an issue here with calculated values in a drawing table (please see attached picture).
Using more digits after the comma is not an option.
If instead floor a ceil option is used the the wrong value goes correct, but the rest of the values for the total weight goes wrong.
Is there a way to have all values correctly calculated.
Thank you in advance.
