SMT_THICKNESS is not updating in multibody after unlink
Hi Community!
As per https://www.ptc.com/en/support/article/CS416999 in order to be able to modify the sheetmetal parts' thickness easily after creating them, we choose to "Unlink from Part" by default (in our start part). But it seems it solved one problem while created another: The problem is that the SMT_THICKNESS parameter is not updated after altering the model thickness. Therefore extracting the material thickness is not possible now 😕
Is there another parameter we can use in order to display the thickness?
Thanks in advance!
-Tibor
