drawing BOM of assembly from imported STP file
  • October 2, 2023
  • 3 replies
  • 2976 views
I have a step file assembly imported into creo and the drawing BOM table sees it as a part. I cannot seem to correct this with any methods I am familiar with.
Best answer by StephenW
@anthonyws
Go to the table table, then repeat region icon, then in the menu manager that pops up, hit Flat/Rec item and pick the table.
I am guessing that Creo is seeing it as a part file and not an assembly. In order for the repeat region BOM to see the assembly structure, your import will need to be seen as an assembly.
anthonyws13-AquamarineAuthor
Yeah, That's what I see but how to do that is the question. I was able to sort of drag the assembly up the list and expand the features (I think I moved the features out of the imported assembly.) I tried a bunch of things and got it to work but without a clear understanding of what is happening, I don't have confidence it'll be repeatable in a reliable way. I'll have to google around. Cheers
When I import step files, I usually get an extra level. So to generate a BOM on a drawing, I would need to either add the model to the drawing that has the structure as I want to see it or  set the bom item(s) in the table as recursive so it goes down to the level I need.
I do remember the recursive trick from some training but for the life of me I cannot find it. It was nested in a dropdown I remember.
StephenW23-Emerald IIIAnswer
@anthonyws
To resolve the issue of Creo recognizing a STEP file assembly as a single part, verify component identification, check file structure, review assembly constraints, configure the BOM, and consider re-importing.
I hope this will help you.
Thanks.
