Dependent holes between parts in an assembly
Is there a quick and easy way to make holes dependent between parts. I have tried to copy and past which works decent if the parts have similar geometry but as soon as I try to edit the holes Creo crashes with a fatal error. Is there another way that works to make the holes dependent without putting the holes in the assembly itself?
