How to use attribute "Outline Number" of Requirement Item in computed field expressions?
Hi dear Community,
I want to use the Item Attribute "Outline Number" of Requirement Item in computed field.
Example: I tried to write the computed filed expression like 'indexOf (<Outline Number>, ".") ' to know, whether Outline Number contains one "." (dot symbol). But I can't use the attribute name "Outline Number" per se, because it contains the blank symbol.
Therefore I need the property name for Outline Number. But this attribute is hidden and I can't see it in attributes' list of Tracker configuration, even if I turn the ticks "show hidden attributes" and "show property names" on.
Please help me to solve this problem. Thank you in advance!
