7-Bedrock
August 29, 2024
USE NOTE FRAMED ON 2 (Creo 10.0.3)
  • August 29, 2024
  • 2 replies
  • 1442 views
I should know is it possible to frame a note with a single frame on 2D model when you want to write on many lines like this screenshot. Because actually I just do frame each line only but not all the lines together.
Thanks for your help if you can give me tips.
Regards.
You are in the wrong forum.
PTC has two CAD systems:    Creo+ and Creo Parametric    and     Creo Elements Direct.
Which makes it confusing.
More, for Creo Elements Direct:
- The 3D software name is Modeling, and
- The 2D software name is Drafting.
For Creo+ and Creo Parametric, use only this tab:
You should move your post to this community to have a better chance to get an answer.
7-Bedrock
September 2, 2024
That's true. Is it possible to change topic category ?
Thanks.
Regards
I do not think so. Either you delete and recreate one or ask the moderator.
I think you are attempting to enclose multiple lines of a note inside a box?
(from another post)
It sure seems that this isn't possible.  Please suggest a product enhancement idea.
