volume milling vs rough vs HSM
Hello Creo experts,
I have a question regarding volume milling. I have often chosen to use rough or HSM sequences instead of volume milling for roughing operations. However, I've noticed that the cycle time for HSM and rough sequences is not as good as I expected. Despite being named high-speed milling, the cycle time is actually longer than the volume milling cycle for the same pocket size. Can you please advise on the parameters I may be missing to achieve a shorter cycle time compared to volume milling on the same size pocket?
Asif Fisa
