Calculation of area under a curve through x,y data points
  • July 27, 2021
  • 1550 views
I am using Mathcad Prime 7.0 7.0.0.0
I have a curve generated using a trace that connects plotted x,y points. How can I use Mathcad to calculated the area under that curve?
    Please attach the Prime worksheet. That will help us answer your question in the best way.
    You should also know that this part of the Mathcad/Prime forum is mainly for installation questions.
    Next time you should post here: https://community.ptc.com/t5/PTC-Mathcad/bd-p/PTCMathcad
    This function calculates the area under the curve defined by x and y data.
    It uses the triangle rule:
    See attached Prime worksheet.
