How to Activate Mathcad Prime 7.0.0.0 Or 8.0.0.0 Using product Code?
1. Run LicenseWizard.exe from default location C:\Program Files\PTC\Mathcad Prime X.0.0.0 ( Mathcad Prime 7.0.0.0 - 8.0.0.0 ) or Launch using Windows #Search and #Run as administrator
2. Select Mathcad Icon M' and then select #M' Options
Select option #License
3. Follow the Steps as highlighted in numerically ascending order and select #Next
4. Enter the Product Code, #Next on Acquire License Page check the product for which the license needs to be activated and select #Acquire License (4)
5. After selecting #Acquire license, a license will be generated for the provided product code. User can double click on the Mathcad Prime icon and launch the application successfully.
7. Now you are all set - You'll be able to launch Mathcad Succesfully!!!!
