3D plot problems
  • September 17, 2013
  • 2 replies
  • 2903 views
Im trying to plot in the function below to see the level curves, but it won't work.
I don't understand the error message, so i hope you can help
23-Emerald I
September 17, 2013
If the radical evaluates to an imaginary number (x = 5 for example) the plot fails.
Prime plotting capabilities are very limited. As Fred already pointed out Prime would refuse to plot anything if a single evaluated value would be a complex number. The same applies if a division by zero occurs.
One way out is to limit the values for x and y so the radical is positive --> -2.8 <= x,y <= 2.8.
Another approach would be to write a function which traps the division by zero and replaces complex values with NaN's (Not a Number).
Third possibility which comes to mind is to rewrite the function using an appropriate parameter representation if possible.
I am not sure what you mean with level curves, but I guess you would need a contour plot. Contourplots dont work with NaN's so I set all complex values to 1. Unfortunately we cannot mix surfaceplot and countour in one graph or use colormaps as in Mathcad.
hm, looks difficult. Can you refer to an other program which is more convenient?
I have 89-Nspire on my computer, but i cannot figure out how to do it.
Here is another well known free program. Restricted in many respects but convenient and can be integrated into M$ Word, too. Its Microsoft Mathematics. No explicit countourplot, though - not sure if you need it.
