Curve fitting - Creep Coefficient
  • December 3, 2024
  • 2 replies
  • 3884 views
I am trying to perform curve fitting using mathcad 13 to determine the best coefficients, "alpha" and "beta," that can approximate the equation of the three-parameter model (red line) to the creep equation according to Eurocode 2 (blue line).
I cannot change the expression of the parameters in the three-parameter model equation. At this point, I have already tried using functions like "genfit."
However, the parameters I am finding are less accurate than those obtained using the trial-and-error method.
I would greatly appreciate any help or suggestions you can provide.
Best answer by Werner_E
I am not sure but it may be hat you got confused about the time units?
Anyway, I just used your vectors X and Y and the function type you provided.
It looks to me that you had provided bad guess values.
But the function type seems not suit the data very well.
There may be other function types better suited. Some examples see below
Werner_E25-Diamond IAnswer
Thank you very much for your attention, Mr. Werner.
I have reviewed your solution; however, I am unable to open the file in my version of Mathcad (version 13.0).
Would it be possible to convert the file to a compatible format?
I appreciate your assistance.
The X and Y data were extracted from the function φ(t, t0), where X corresponds to specific points on the x-axis and Y to specific points on the y-axis.
Is there any possibility of using the function itself instead of specific points from the matrix?
For example, one idea would be something like this:
The other idea I mentioned above involves using alfa1(t, t0) and beta1(t, t0), where these coefficients would also vary over time to better fit the creep curve. I'm not sure if it would work this way, but I'm thinking and trying solutions for a better automatic adjustment.
Bom dia,
I fail to see the point of curve fitting. Following your sheet I find:
that define:
and:
that define:
to finally define:
So the function you are trying to approximate is actually
With the values:
this plots as:
So the shape of your function is determined with only four parameters.
Why settle for less accurate results in two or three parameters?
Hi Mr. Luc Meeks,
I truly appreciate your attention to my question and your opinion.
Indeed, the creep coefficient depends on many factors, such as the age of the concrete at the time of load application, curing conditions, environmental factors like relative humidity, the level of applied stress, the duration and history of loading, the dimensions of the concrete elements, the material composition, and other factors.
I am attempting to simplify this by using an equation that depends on the modulus of elasticity and the viscosity modulus of the concrete.  While it may not achieve 100% precision, will provide a good level of accuracy.
I am attaching an article containing parts of my research, where the next step involves refining this curve as accurately as possible using a programming routine.
Any criticism, considerations, or suggestions are always welcome.
