Find minimum non zero value in a matrix
oguest
Hi, is there an easy way to find the non zero minimum in a matrix?
Or is a loop the only way to do it?
This is what i have at the moment.
5 REPLIES 5
StuartBruff
23-Emerald V
(To:oguest)
Try this ..
Stuart
Maybe a user defined function could work for you.
Mike
oguest
(To:oguest)
Thanks for the suggestions guys. I realized that I needed to have a tolerance in there as some of my values were very close to zero. So I went for this:
StuartBruff
23-Emerald V
(To:oguest)
Hi Oliver,
Is b guaranteed to be  non zero or an in-tolerance X to never be negative?
Stuart
oguest
(To:oguest)
Hi Stuart,
Yes for this particular task it wont ever be negative or exactly zero.
Oliver
