How can I set trigonometric functions to be in degrees (nor radians)?
  • November 20, 2015
  • 3 replies
  • 33083 views
I am working on problems where all the angles are in degrees and the trigonometric functions should read them as such. It is a lot of work to make sure that all the angles are converted to radians before the algebraic expressions involving them are evaluated. Is there any way that a statement or preference can be added so that mathcad correctly evaluates the trigonometric functions with the arguments in degrees?
sin(90 deg)=1 m/m
cos(90 deg)=1m/m
asin(1 m/m)=1.572 rad
asin(1 m/m)=90 deg
asin(1 m/m)=100 grad
etc
Or you can use Mathcad Prime Minister
Rad Deg Grad Etc
There is no option to change the default (pseudo)unit of angle to something else than radian.
If you want a length to be in meter you write m, if it shoul be interpreted as feet you write ft.
The same applies to the pseudounits of "dimension"  angle. If you want a quantity in degree, you have to write "deg" or "°".
If you want it in radian you either write "rad" or nothing at all, as rad=1.
If you are using the symbolics they don't know anything about units and will treat deg or ° as unknown variable. So you would have to define °:=pi/180 and/or deg:=pi/180 yourself.
Werner Exinger wrote:
as rad=1.
Sorry, rad=1 m/m
or
rad=3.281 ft/m
etc
as rad=1.
Sorry, rad=1 m/m
... and m/m is ...?
The ratio of two lengths is a dimensionless number, in our case rad=1.
It doesn't matter if you measure in meter or feet or mixed length units.
Mathcad knows about that ;.)
23-Emerald V
November 20, 2015
Either use the built-in unit conversion facility or redefine the trig function to work in degrees.
Stuart
