Looping in Mathcad
NM_10165576
Looping in Mathcad
I want to get several options as shown in picture.
could someone help me with this.
Attached the Mathcad sheet.
Hi @NM_10165576
I recommend giving more details and context about the problem you have in mind. Please refer to this guidline to make your questions more likely to receive a quick and useful answer.
Catalina
PTC Community Moderator
PTC
This program used to give me several options to arrange the rebars in a beam cross section in one layer.
Now i want to make it as a function and use it for several layers.
CS is the spacing between the bars. If it exceeds sn, which is minimum spacing between the bars, it should automatically go to second layer and place the bars there.
Attached the file, which works for one layer. I do not know how to loop, so that it considers the bars in second layer.
could someone help me here.
Here i am calculating required Ast usind effective depth d, which is dependent on Sp, that CG of the bars.
