Not defined units
Venetank
Not defined units
I have been struggling with a problem that I defined units as kg/m, but as seeing above, there's no unit at all. Moreover, the number is different. The picture is only a fracture of my work, but I couldn't find any cause of the problem from the work which is not shown on the picture. What would cause such a thing? http://picasaweb.google.com/jur.pik35/Album#5459965925017582690
RichardJ
(To:Venetank)
Without the worksheet it's impossible to be sure, but the most likely answer is that somewhere in the worksheet you defined m as a mass. That overrode the definition of m as 1 meter (there is no distinction between m as a variable and m as a unit). It also means the units for q cancel, because you have mass divided by mass. Unless you turned the warnings off (or you are using an old version of Mathcad) you should have got a warning when you redefined m. It will have a green zigzag line under it, and if you select the m it will say "This expression redefines a Mathcad built-in unit" Richard
You are the muthaphukkin genius! THANKS A BUNCH! Case closed!
