Everything seems correct, but my graph doesn't come up...any ideas?!? Thanks.
I don't see how I can insert my document here...or I would
Try this: delete w.t and deg and then write t instead w.t because your functions Vdc and Idc are function of t, and not function of w.t
Thank you for your explanation.
Use
at x-axis.
