Plotting using text
tietjee
Plotting using text
I would like to plot using text (Jan, Feb, Mar, etc) my calculations using integers, but it is hard to see the results. Any suggestion
6 REPLIES 6
Could you post an example of what's required, or at least close to what you want.
Maybe show what you have previously been producing.
IRstuff
(To:tietjee)
In general, that's something I would port to Excel and plot therein
TTFN
Good idea the data could be passed to Excel and the graph produced there. Inserting Excel components is messy and usually takes a lot of playing around though.
You can place text boxes over the required sections of the graph.
Cheers
Mike
RichardJ
(To:tietjee)
You label the exes of Mathcad graphs with text, so, as already suggested, an Excel component is about the only option. Your only other option is to download the e-book here:
http://communities.ptc.com/community/mathcad/mathcad_usage/blog/2010/05/27/creating-amazing-images-with-mathcad-14
That shows you how to put text on graphs, but you still have a lot of work to do to make a labelled axis!
I have just downloaded and installed the suggested e-book which has some fantastic features - A little above my Mathcad knowledge I must add. I doubt the original poster will find what he is after in there.
If he is after labelled axis - Excel is the way to go.
I only said it was a possible solution. I never said it was an easy one
