Toolbox: Text plotting
  • December 25, 2021
  • 5 replies
  • 14271 views
Attached is a Prime 4 file that allows you to plot text in a graph, like:
Of course it runs in Prime Express...
Enjoy!
Best answer by LucMeekes
Hi Werner,
Thanks for pointing that out. I think it's corrected now.
Thanks!
23-Emerald V
December 27, 2021
Very neat, Luc.  Concise, too.
Stuart
Thank you
Can I plot in 3D?
LucMeekes23-Emerald IVAuthor
I don't know. Prerequisite is that you have access to the full functionality of Prime. I'm limited to Express...
The text plotting functions create matrices of many rows and two columns. I think that for 3D plotting you'd need 3 columns. Now it's easy to augment the matrix with another row. Suppose T is the output of a text plotting function then you could add the third column with:
     T:= augment(T,update1(0,last(T),0)+z)
to position your text on the x-y plane at elevation z.
The other thing is that the T will contain NaN values. I don't know if the 3D plots will accept them.
P.S. The better way to create the z-coordinates may be:
Which will preserve the NaN values.
ttokoro
E** with both direction.
t.t.
Corrected errors that prevented it from working with ORIGIN values other than 0.
Great @LucMeekes  both 2D &3D.big thank
maybe this last question hahaha. how to convert from Number to Text in Prime for Plot Number?
Best regards SPRSTRUCTURE
Use the num2str() function:
Hi, do you know if it's possible to plot text like this in Mathcad 15?
Yes, I do know.
And.
Yes, it's possible.
But I haven't created a Mathcad sheet yet with a copy of what's in the Prime sheet.
If you are in a hurry, have a look at the E-book "Creating amazing images" by Byrge Birkeland.
