Vectors in Mathcad
DanielleSavage
Vectors in Mathcad
I am using vectors in mathcad. For some reason when i divide two vectors it produces a scaler. Any ideas on what I am doing wrong?
D
Yes, the vectorize operator is the way to go.
The vectorize operator can be found on the matrix toolbar.
Mike
7 REPLIES 7
Can you post an image of the problem I currently don't have Mathcad?
Are you trying to divide element by element? If so, you could use the vectorize operator.
Mike
Hello Mike,
I have attached a picture of the code. And I lied. I'm trying to multiply to vectors together; Vel_D and D_D.
I appreciate your help,
D
I now have Mathcad can you post the worksheet.
Looking at the image it seems that the vectorize operator will work.
Mike
No problem. I have attached the worksheet.
D
Mike
Thank you so much Mike.
Cheers
Defining vector multiplication (or division) using the standard multiplication sign has always been assumed to be the vector dot product, which results in a scaler answer. (The cross-product is available for three-element vectors.) To multiply element-by-element requires that the product be "vectorized," as you have already found out. It can also be done by indices, but the process is much slower.
