install mathcad prime
  • August 18, 2018
  • 2 replies
  • 3526 views
Dear ptc-community,
I currently have a problem re-installing mathcad Prime.
When using the installer-file (pim_installmgr_mathcad) I can only get to the third page, where I usualy dicide which part of the software to be installed (I attached a screenshot). Now this page is empty, so I can not finish the installation.
Does anyonne know a solution? Or could it just be an issue with the ptc-server and I only have to try it another time?
my OS is Windows 7 professional x64.
This seems to be a common problem which luckily I did not have to experience yet.
Here's the link to a thread where some people report the same problem. Unfortunately no problem fix so far.
https://community.ptc.com/t5/PTC-Mathcad-Questions/PTC-Installation-assistant-is-blank-when-selecting-MathCad/td-p/565459
You may consider contacting PTC support.
s766781-VisitorAuthor
Thank you for the quick response.
So maybe I'll just be patient an try it again later.
Please send your issue for technical support here: https://support.ptc.com/support/mathcad_supportCenter.htm
