8-Gravel
August 29, 2018
CREO Parametric 5.0 - Error with Drawing template license
  • August 29, 2018
  • 3002 views
Using CREO Parametric 5.0 (5000): After creating a part model, and starting a new drawing using the default c-drawing template an error appears:
"The file C:\ProgramFiles\PTC\CREO5.0.0.0\CommonFiles\templates\c_drawing.drw was created in a commercial version and is not compatible with this version of CREO Parametric Student Edition"
It is using the built in templates, so how do we get CREO to allow this template to open up? It will start a drawing without a template, bu then no default views are added. This version was installed using the PTC Student (University, not K-12) install guide as found on PTC.
Please download the templates from this link:
http://apps.ptc.com/schools/references/templates.zip
unzip them and replace the original folder with the one downloaded in C:\ProgramFiles\PTC\CREO5.0.0.0\CommonFiles
Alex
mcbooya8-GravelAuthor
8-Gravel
August 30, 2018
Do they need to pasted directly into the Common Files folder, or into the "Templates" folder within the Common Files directory?
Please replace the templates folder with the unzipped one.
