Creo Parametric 9.0 setup.exe failing to run
I am attempting to install Creo 9 on my Windows 11 Pro 64bit (i7-10875H) laptop.
Running setup.exe (version 37.0.2022.72) as admin fails to run.
Event viewer states:
Faulting application name: setup.exe_Creo, version: 37.0.2022.72, time stamp: 0x62555a35
Faulting module name: baselibmt.dll, version: 37.0.2022.72, time stamp: 0x624c4ccc
Exception code: 0xc0000005
Fault offset: 0x0000000000018a9a
Faulting process id: 0x0x2C40
Faulting application start time: 0x0x1D8ED415056357A
Faulting application path: C:\...\MED-100WIN-CD-460_9-0-0-0_Win64\setup.exe
Faulting module path: C:\...\MED-100WIN-CD-460_9-0-0-0_Win64\pim\x86e_win64\baselibmt.dll
Report Id: 6a270cba-6530-41d2-b155-f1afeba02613
Faulting package full name:
Faulting package-relative application ID:
Following another post's instructions (Solved: running setup.exe does nothing - Creo 8.0 - PTC Community) for Creo 8.0, I have disabled hypervisor. The issue still persists.
I attempted to install it within a Windows 10 Pro Hypervisor VM on my computer, which was able to install Creo Parametric 9 successfully but immediately crashed upon making a new part file - I assume due to running inside a VM.
Creo Parametric 8 installs and runs correctly on my machine, no errors when installing or creating parts.
Creo Parametric 9 also installs fine on my Surface Pro 8 running Windows 11 Home.
The issue is with installing Creo Parametric 9 on Windows 11 Pro specifically from what I understand. Are there any workarounds to install Creo Parametric 9 on Win 11 Pro successfully?
