The device is unable to connect to composer 6, it has https. Before on composer 5 the same device was working fine and was uploading data without errors. If any one had the same problem and have any solution kindly share it. Thank You
Are you sure that ssl is set up in Tomcat properly? Are you able to connect to composer using https:// and port 8443?
Thanks!
Tori
Harshal, have you pointed it to the right port? Do you have a flag to set isSecure to true?
Yes, I have put Port as 443
Can you post any error logs that get printed out?
