Intel Galileo gen 2 connection problem to thingworx with composer 6 having HTTPS
hjaurkar-2
The device is unable to connect to composer 6, it has https. Before on composer 5 the same device was working fine and was uploading data without errors. If any one had the same problem and have any solution kindly share it. Thank You
ttielebein
(To:hjaurkar-2)
Are you sure that ssl is set up in Tomcat properly? Are you able to connect to composer using https:// and port 8443?
Thanks!
Tori
Aanjan
(To:hjaurkar-2)
Harshal, have you pointed it to the right port? Do you have a flag to set isSecure to true?
Yes, I have put Port as 443
Aanjan
(To:hjaurkar-2)
Can you post any error logs that get printed out?
