8-Gravel
November 30, 2016
Possibility of running Creo 3.0 on Amazon cloud server or Azure
  • November 30, 2016
  • 4540 views
hi,
i was trying to run Creo 3.0 academic version on Amazon Web Server, it's a Windows Server 2016 system. Hardware requirements are reached. Running on single Xeon E5 processor, I installed Creo and license without any problem, but when I try to open it, it said it's a student licenses and does not have feature for floating license. It's there a way to apply for floating education license? Because running on Amazon gpu optimized server should save a lot of time and we actually got sponsored by them. We also tried distribut computing, but I don't think academic version support it.
    Best answer by MartinHanak
    if you are K-12 school, then you can request floating LAB license (qty 150). Go to Creo K-12 Educator | PTC page, fill the form, click Submit. On next page you can request Premium Lab License.
    If you need to get only 1 floating license, then ... I do not have any idea, how to request it. If you tell me where is your school located, then I can ask my PTC contact, who at PTC is responsible for your area.
    MH
    Gary Chen‌ I moved this discussion into the Academic Support‌ community since it will ultimately involve a request to - for a floating license of Creo.
    gchen-28-GravelAuthor
    8-Gravel
    December 11, 2016
    Ummm floating license as Christmas gift? Possible?
    I hope you have done your homework on this one and know what type of instances to request from each provider. OpenGL support is not provided in an evaluation instance from either vendor. For AWS, you'll want a g2 instance, which is not inexpensive to own and operate.
    If you really want cloud based CAD, why not go to OnShape? Seems like a lot of effort to install, license and configure Creo in an IaaS manner that will be sub-par w/o full OpenGL support.
