Driver hp designjet 755cm Windows 7
  • September 28, 2010
  • 5 replies
  • 1850 views
We have the same problem here with our 1055cm. It's been suggested to
look for and try Vista drivers, sometimes they still work with Windows
7. Haven't tried it here yet.
Doug Schaefer
    I just found the drivers for my plotter.
    I went to start -> Devices & Printers and clicked 'Add Printer' at the top of the window. I then followed the prompts to install a network printer. Mine is attached to the network directly, so it wasn't on the list, I had to enter an IP address. Then, it asked me to select it from the list. My HP 1055cm wasn't on the list, but once I clicked 'Windows Update', the list was refreshed and it was there. It installed just fine, however, it won't print via the command I used with XP (lpr -S <ip address="> -P <ip address=">). It does work through Windows Print Manager.
    If I go to a DOS prompt and type 'lpr', I get ''lpr' is not recognized as an internal or external command, operable program or batch file.' I wonder if command line printing in Windows 7 is different ...
    Doug Schaefer
    Thanks for the info, my copy of Windows 7 was missing the Windows Update button in the Add Printer dialog. I finally found that someone had turned off the reg settings that allow that button to show.
    HKEY_LOCAL_MACHINE\SOFTWARE\Policies\Microsoft\Windows\DriverSearching
    REG_DWORD DontSearchWindowsUpdate to '1'
    REG_DWORD DontPromptForWindowsUpdate to '1'
    Reseting them to 0 cures the problem.
    David Haigh
    I'm trying to get my server controlled publishing to work again, and I'm running into a problem with proeworker.bat not starting up properly under server control.
    If I try to publish an object from windchill by clicking on the pyramid, the system hangs at Registering Server.
    Sep 29, 2010 3:02:15 PM:Start PublishJob: Assembly - <name>.asm, AA.0
    Sep 29, 2010 3:02:15 PM:"As Stored" Config Spec is available
    Sep 29, 2010 3:02:15 PM:The EPMDocument As Stored Config Spec was selected as the default
    Sep 29, 2010 3:02:15 PM:make temp dir <path> \pubtemp\publish666537055655258760.tmp
    Sep 29, 2010 3:02:15 PM:Start: Assembly - <name>.asm, AA.0
    Sep 29, 2010 3:02:15 PM:Authoring Application: Pro/ENGINEER
    Sep 29, 2010 3:02:15 PM:empty temp dir: <path>\pubtemp\publish666537055655258760.tmp
    Sep 29, 2010 3:02:15 PM:Transferring Files to: <path>\pubtemp\publish666537055655258760.tmp
    Sep 29, 2010 3:02:15 PM:Number of Files (identified to be) Transferred: 7
    Sep 29, 2010 3:02:15 PM:ProE Asm Conversion
    Sep 29, 2010 3:02:15 PM:Added request to PROE queue
    Sep 29, 2010 3:02:16 PM:No available connected worker
    Sep 29, 2010 3:02:16 PM:Starting new worker <server name=">-PROE:1, attempt 1 of 3
    Sep 29, 2010 3:02:31 PM:Job 14 submitted to worker: <server name=">-PROE:1
    Sep 29, 2010 3:02:31 PM:LOGID: worker_3.log
    Sep 29, 2010 3:02:31 PM: Registering Server
    However if I remote into the worker machine and start proeworker.bat from the command line, then publishing works. To be clear, I'm starting that as myself, not the windchill user I have in the fileadapterauth.properties file. That user is just a windchill user. It has no login to the worker machine on its own. This used to work.
    Any ideas? Suggestions?
    David Haigh
    Phone: 925-424-3931
    Fax: 925-423-7496
    Lawrence Livermore National Lab
    7000 East Ave, L-362
    Livermore, CA 94550
    ________________________________
    In the Update Group dialog there used to be a pick for recomputing the team membership.
    In 9.1 I no longer see it. Where did this go?
    [cid:image001.gif@01CB608C.C66C10D0]
    David Haigh
    Phone: 925-424-3931
    Fax: 925-423-7496
    Livermore, CA 94550
