Installing Creo 2.0 on second computer
  • October 9, 2013
  • 3 replies
  • 8723 views
Trying to install Creo Parametric 2.0 for a colleague (let's assume Aydee). Aydee is already using Creo on his work laptop, but it is slow, for the work he does. Very slow. I and Aydee would like for him to try Creo on a desktop computer, and see if it runs faster than on his laptop. The software installation is asking for a license. Should I enter the PTC Host ID for Aydee's laptop?
I have my license on the laptop, so I can use it after hours as I am on 24/7 call, but like you I found it to slow for day to day operation.
My main PC IS 64 BIT , so I can make use of the full memory, 32bit is restricted to 3g
When you set it up and it asks for the license, you need to point it at the laptop name that has the license file, it should find it and return 7788@ "pc name".
As long as the laptop is running and only one version of Creo is open, it shouldn't be an issue
Please see attached image, for the license prompt. What should I click on, to browse for the license?
You can ask PTC to move locked license from laptop to destop. BUT after this step you are not allowed to continue using locked license on laptop.
If you bought locked Creo Parametric you cannot ask PTC to send you floating license. Locked Creo Parametric and floating Creo Parametric have different ORDER ITEM number.
Martin Hanak
I were you , I will buy another license .It is not expensive at all
I hate illegal software so much . Every software I use is legal
Windows 7
MS office 2010
Catia
Autocad
and more
OK??????????
The answer is yes, you can install onto a USB network card.  Works fine.
