On computers that do not have a discreet graphics card, the client UI lags quite a bit. Is there a known fix for this? These computers have Intel HD Graphics. I have seen this on a Dell laptop running Windows 7 and a Dell tablet running Windows 8.1.
Maximum Heap Size is set to 1024 MB.
Popup Status Delay has been set to different values between 0 and 2500 (default).
It looks like changing the power scheme from Balanced to High Performance may have fixed it. I'm going to have a few people mess with it and see how it looks.
What kinds of operations are slow, or is it everything in general (eg. selecting a drop-down menu, waiting for a dialog to pop-up, etc)?
If it is a rendering-related problem you can try a few things:
Individual drivers generally aren't a problem with Integrity but if those suggestions above don't work, open a case for us to take a closer look.
Ah yes, especially if the machine is a laptop. The power settings can really throttle down the CPU and has been known to introduce performance issues.
I would recommend adding that to the article you referred me to.
Done. Thanks for the reminder about that setting!
