Adding text to Longtext
Hi Team,
When editing an Issue manually, the existing contents in the field (its a longtext with logging disabled) will be visible in Edit mode.
But when using CLI command, i'm getting only the option to overwrite existing value.
Is there an option to add content to field ?
*I tried storing the current value to a temp variable, add my new contant to the temp and use that variable to edit field - but this is not working in batch script when field length is big.
Arun
