Export to Word - problem with field Expected Results
  • October 18, 2014
  • 1724 views
I'm trying to export a Test Suite and its Test Cases into a DOCX file with the gateway export wizard.
I succeed in displaying each test cases of my test suite like this :
id - Text - Category
My problem is that I would like to display also the field Expected Results but I don't know why I can't do it. I am using <%{Expected Results}%> to get it as I do for id or text (like that <%{Text}%> ) but it doesn't work.
Does someone have an explanation for this?
Thank you
N. Lateral
    Best answer by mrump
    Hi Nico,
    have you checked whether the field "Expected Results" is part of your export mapping configuration file?
    You need to tell the gateway which integrity internal field it should use to fill the"placeholder" <%{Expected Results}%> in your WORD Template.
    HTH Matthias
    mrump16-PearlAnswer
    Hi Nico,
    HTH Matthias
    Great ! It works !
    It was so obvious that I didn't think of it..
    Thank you.
