Get the date when an Issue entered in a given state
  • February 10, 2015
  • 1457 views
Hi, guys. I am trying to generate a report containing in some columns the date when an issue entered in a given state. For example, if an Issue entered in Classified state today, the actual value will be 10/02/2015 or whatever date format is used by Integrity.
Can this behavior be achieved? The support team from my company told me that this isn't possible, but I want to hear other opinions.
What bothers me is the fact that the date that I want is available in the History tab of the issue, but I cannot get it.
I attached a file just to be more clear.
Thanks in advance.
    Best answer by mrump
    This is possible using a computed Expression:
    There are some usefull computed expression function classes available that should do the trick.
    dateFirstEntered(state-name)
    Returns date specified state first entered.
    Timestamp
    dateLastEntered(state-name)
    Returns date specified state last entered.
    Timestamp
    HTH Matthias
    mrump16-PearlAnswer
    Timestamp
    Timestamp
    HTH Matthias
    oostoia1-VisitorAuthor
    Thank you very much, @Matthias.
