Has anyone successfully run Integrity PC Client in a Citrix environment
  • October 5, 2015
  • 2 replies
  • 5430 views
Has anyone successfully run Integrity PC Client in a Citrix or other VM environments?
    Best answer by JoeBartlett
    Hi Todd,
    Running Integrity on Citrix is not supported but some customers have gotten it to work with a couple tweaks. See Article 84832 for details on a workaround you can try.
    Hi Todd,
    Hello Joe,
    What about VDI? Like if a user uses Horizon view client to connect to a Windows 7 VDI. Is it a supported configuration?
    Thank you,
    Binesh Kumar
    Barry Wehmiller
    Good question, since I am not familiar with VDI. I am confident that it is not officially supported because it has not been tested with Integrity, however, if it functions the same as any other VMWare environment it should work. If it is allowing multiple users to access the same binaries under different user accounts, that is a situation where the workaround in Article 84832 should be used.
    Not sure if this is helpful or not for what you are looking to do, but you can run it inside of Sandboxie. I use that to use the 10.5 and 10.7 clients from the same computer.
    Off topic:  Thanks for the Sandboxie reference.  I hadn't heard of it until this post, but it looks like it could be useful.
    -Kael
