How can I remove the "GMT" information from a date field?
  • February 17, 2015
  • 2960 views
I have a computed date field (date only, not timestamp) that uses the function firstTimeEntryDate() to find the earliest time entry on an item.
The output looks like this: Jan 13, 2014 GMT+00:00
I want to get rid of the useless "GMT" information.
My first instinct is to try to parse the date and reformat it, so I end up with something that looks like this:
timestamp(
concat(
Substring( MonthOfYearName( firstTimeEntryDate() ) , 1 , 3 ) ,
Text( " " ) , ToText( getDay( firstTimeEntryDate() ) ) ,
Text( ", " ) , ToText( getYear( firstTimeEntryDate() ) )
This doesn't work because "The Timestamp() function takes a single argument which must be a string in the format java.text.SimpleDateFormat".
I know I can do the parsing into a text field, but I want a date.
Does anybody have a solution to format a computed date field, or more specifically remove the GMT information?
    Best answer by KaelLizak
    Hello Laurent,
    This issue is covered by RFC 107695. Please open a case with PTC Integrity Support to add your organization to it.
    Warm Regards,
    Kael
    (Edited 2015-02-18EST10:48 by Kael: Mis-typed RFC number as 107696 instead of 107695)
    KaelLizak16-PearlAnswer
    Hello Laurent,
    Warm Regards,
    Kael
    Hello Kael,
    I like to have a look into the SPR.  Does also exist an SPR no. for it?
    Klaus
    Hello Klaus Hoppe‌,
    Because that RFC was a feature request rather than a defect report, it does not exist as an SPR.  I searched the existing Ideas, and found there is an Idea which might be interpreted as being close:  Override locale information on date fieldsYou probably want to create your own Idea to reflect RFC 107695/CS85012.
    Kind Regards,
    Kael
