6-Contributor
March 31, 2015
How to check for updates to the Implementer Plug-in for IBM Rational Developer for i?
  • March 31, 2015
  • 3556 views
When in IBM Rational Developer for i I do a Help, About, and see I am at Version: 7.1.0.75 of the Implementer Plug-in. How do I check for updates?
    The Implementer plug-in for Rational Developer is just a regular Eclipse plug-in ... so you would use the built-in plug-in update procedure.
    Do the following:
    • Click on the Help menu
    • Select Install New Software... (you could use the Check for Updates, but I find the Install New Software option faster).
    • When the Available Software dialog is displayed, select the software site that you setup for the Implementer plug-in.
    • If there is a new version of the plug-in available, it will be shown.
    NOTES:
    1. The Implementer plug-in is tied directly to the version of Implementer being used ... if there is a new version available the plug-in will require an update in order to function.
    2. The Implementer plug-in does not rev very often. Usually only on a new Implementer version install/upgrade. Chances of an update being required is fairly slim.
    rberendt6-ContributorAuthor
    6-Contributor
    April 1, 2015
    Thank you for your reply.
    Is there a chart listing Implementer level compatibility with Plug-in? Like "Version . . . : 11.0" of Implementer goes with 7.1.0.75 of the Implementer Plug-in?
    6-Contributor
    April 1, 2015
    IDSPVER indicates
    Implementer 11.0 (build 7.1 140429)
    so 7.1.0.75 matches "7.1 140429" because of the 7.1 alone, right?
