IBPL field Java API vs cmd
  • September 17, 2018
  • 1524 views
Dear all!
Integrity Version 11.1
Calling
mksapiviewer --xml --iplocal  im viewfield --user=administrator --password=password --hostname=localhost TestIbpl
Got:
<Field name="backingFilter">
<Value dataType="string">((field[Text Attachments] has at least one attachment))</Value>
</Field>
But
Issue Backed Pick List:
Backing Type: Change Order
Backing Text Field: Summary
Backing Text Format: {Summary}
Backing States:
Backing Filter: (field["Text Attachments"].hasAttachments)
Display As Link: false
Sort Field:
Sort Descending: false
Is it possible to get correct value via Java API?
    I'd consider this a defect  as you cannot take the output from the API and use that to create a new filter.  I suggest contacting PTC Support to log an SPR.
    I can't find a way to get the right value in the API.
