Integrity 2010, how can I tell who is signed on to the system right now?
  • June 20, 2016
  • 2 replies
  • 1687 views
I believe I found it: Server Diagnostics and then License usage. Thanks.
    Best answer by dmirkovic
    Hi Michael,
    License usage will provide the license usage statistics for the Integrity Lifecycle Manager server application. To identify who's currently logged/signed into the system, while in the Administration client, you can expand Server Diagnostics and then use Client Connections, then select the run button.
    Dragan
    dmirkovic12-AmethystAnswer
    Hi Michael,
    Dragan
    July 14, 2016
    You can also use CLI command si diag --diag=licenses which will give you the license statistics.
