Is there is any way to create a query for multi level relationship
  • September 29, 2014
  • 2 replies
  • 1931 views
Is anyone know how to create a query for multi level relationship
For Eg:
Level : 1
Level : 2 (related Item)
Level : 3 (related Item)
Level : 4 (related Item)
How to retrive the list of Level 4 items from Level 1 (Using ID) from a Query?
Shankar
    Best answer by mrump
    Hi Shankar,
    unfortunately there is no way to receive this information using a query.
    This is only possible using a report started for your level 1 item(s).
    Note:
    The relationship filter in the query designer only allows you to filter for "Level 1" items that have a relationship to "Level 2" item which fulfill certain criteria.
    HTH Matthias
    mrump16-PearlAnswer
    Hi Shankar,
    Note:
    HTH Matthias
    Hello Shankar,
    Matthias is correct:
    • ​Not available because the functionality does not exist
    • Reported to R&D as enhancement RFC 145864 via CS88090
    • Please contact PTC Integrity Support if you wish to be associated with this enhancement request
    Kael
    Hi Shankar,
    I did a lot of researched and developed already some add-on solutions in the area of tracing and relationship trees.
    I am interested to know which use case is behind your question. What do you try to accomplish with such a complex query?
    Volker
