Need help with command-line syntax of 'im editfield'
  • September 22, 2014
  • 1604 views
Can someone provide an example of the 'im editfield' command that sets the set of a pick field from active to inactive?
I have tried the following, and a few variations, without success.:
im editfield --picks="value=9,Inactive" "my test field"
Our ultimate intent is coding this in a script. So an example in JavaScript that's invoked by a manual trigger would be even better.
-Sean
    Best answer by mkiessling
    Hi Sean,
    you can set pick fields to active, if you list them in your command.
    The other way round: pick fields are set to inactive, if you don't list them.
    E.g.: Field "my test field" with pick values "green" (0), "yellow" (1) and "red" (2)
    The command
    im edit field --picks=green:0:none,red:2:none "my test field"
    sets the picks "green" and "red" to active, and sets "yellow" to inactive.
    The syntax for the --picks-option is: <text>:<value>:<image>,...
    Hi Sean,
    The command
    Hi Markus,
    Thanks for the information. I'll give that a try.
    -Sean
